no luck--again
chief 83
01-07-2007 21:16:22
Well no luck again today. Tried to get the Super 55 diesel to start, it was a no go. Previous owner indicated at least 8 years of sitting--I'll guess a few more than that. Bled injectors 6 or 7 times, heated up the intake, a bit of starting fluid and pretty much nothing but a little smoke. Return fuel still looks a bit off, maybe a little water still in it but I can't tell for sure. Any suggestions on where to go from here?
chief 83
01-08-2007 17:53:47
 Re: no luck--again in reply to chief 83, 01-07-2007 21:16:22
Didn't mean to scare anybody. I've had the head off, the pistons were stuck. Those were all freed up with some soaking. I'm using a fuel can, not the original tank so the fuel is ultra clean. All new filters. Clean fuel visible in the sediment bowl. Bled at the injectors (fuel showing at all of them). I think I can pull plugs out on the opposite side of the engine from the injectors and put some oil in. I'd hate to pull the injectors again since I would need to start the bleed process almost over again but could do that if you all think it best. I don't know what the sleeve is on the injector pump. Hopefully I've not done anything to hurt the thing--I don't think I have. I'm also wondering about the valves. Should I loosen them way up to be sure they are all seating and adjust them after it is running?
El Toro
01-10-2007 07:28:42
 Re: no luck--again in reply to chief 83, 01-08-2007 17:53:47
You probably need to run a compression check on the engine. Hal
rrlund
01-09-2007 08:09:35
If the engine was stuck,you are going to be fooling with that thing until the cows come home. I"m telling you,the rings are froze up in the grooves. Like I said before about that crawler,the engine wasn"t stuck,never was. The previous owner had the valves ground,thinking that that was the problem. It still wouldn"t start. My brother messed with it until he was sick of it. I pulled the pistons out and every ring was frozen in every groove of every piston. I soaked them in benzine in the parts cleaner and 1 oil ring came loose. I had to use a small punch and break the rest out of the grooves in little pieces. New rings and bearings and it started right up for the first time in several years.
J Schwiebert
01-08-2007 13:10:16
O. K. You scare me your comments on the fuel system: The first thing I would have done would have been to see if the pump's control sleeve was free. If not I would have pulled the pump! The next thing I would have done would have been would have been to drain all the old fuel, put at least a new primary filter in, drain the final filter, put some good quality fuel in and then bleed it. Does it bleed with the starter? I hope you did not twist the plunger off: Rebuilt heads are about $800.00 Good Luck
old
01-08-2007 11:26:08
I agree with Hal. The rings are probably sticking on the pistons and your not getting the compression you should be getting. Get some tranny fluid into the cylinder and let it sit in them a few days. Then give it a try. I've seen a good many engines that wouldn't start becasue of low compression and after a few days of tranny fluid in the cylinders they start right up.
El Toro
01-08-2007 08:52:48
I would do as Mike suggested. Pour some ATF into those cylinders and let them soak. Then see if it will start. You should have a good flow of fuel on the return. Hal
rrlund
01-08-2007 06:40:35
My brother bought a small diesel crawler that did the same thing. I finally tore it down for him. All of the rings on all of the pistons were froze up. Put new rings and rod bearings in it,bled it and it started right up.
MIKE FRENCH
01-07-2007 21:24:25
Put some oil in the cylinders of the engine, has lost compression. Hope this helps.
