550 hyd hookup
Leaky Boot
01-07-2007 07:56:45
No external Hyd valve. Small plat on right side under front of seat. Held by 3 bolts and has a pipe plug in center. If I remove plug do I get pressure from the hole??
Skywalker3
01-07-2007 11:14:24
 Re: 550 hyd hookup in reply to Leaky Boot, 01-07-2007 07:56:45
Do a search on this forum for "550 hyd" or "550 remote hyd" Lots of discussion on this subject with only a few good solutions. I have some type of Cessna Power Beyond valve on mine. Sorry, I don't know where it came from. It is really nothing more than a chunk of iron with ports that allows hoses to be hooked up. It has an internal relief valve which does not function. I have a 3 spool valve to run a loader and 1 remote hyd hook up with an internal relief in it. Look through the archives I mentioned in search above. Some guys have machined their own block to bolt on where your plate is. Best of luck.
J Schwiebert
01-07-2007 09:41:43
Real quick: All the fluid does there is in simple terms is make a change in direction from the pump to the internal valve controlling the 3 point. There are TWO ports under that cover. One out one back in. Now you tell us what all you have in mind. There are also 2 other ports that have pipe plugs screwed into them. Now you tell us what you have in mind and how you are planning on getting there. J.
