77 double disk breaks
Ryan Lichtteneg
01-01-2007 16:09:00
I am having a problem with the inner disk on my 53 Oliver 77. It is very stuck and the seal behind it is leaking crankcase fluid. Do I need a puller to get this off? I have tried liquid wrench and WD40 but still no luck not to mention it is hard to get a grip on the blasted thing. I am not very familiar with these breaks and I am not sure what to try next. Do you have any suggestions on how to get this disk off so I can replace the leaky seal?
Thanks
J Schwiebert
01-01-2007 16:23:29
 Re: 77 double disk breaks in reply to Ryan Lichttenegger, 01-01-2007 16:09:00
I can remember a few cases like that. At one time I had two little hooks made that were on the priciple of rolling head pry bars or "lady fingers" as some people called them. The suface tension of the oil is helping to hold the disk on the splines. Once you pop it loose it should come right off. Now I have never seen a 77 with this set up but there were some. Depeninding on serial number, do you have a large nut in the center and on the end of the bull pinon?
Ryan Lichttenegger
01-01-2007 17:27:01
 Re: 77 double disk breaks in reply to J Schwiebert, 01-01-2007 16:23:29
No there is no large nut at the end of the bull pinion. It is a late model 77.
