PTO failure
David Lee Hawki
01-01-2007 08:42:58
I was digging post holes with a 9" auger... Now the lever that engages the PTO moves much farther forward than before. The PTO spins some but with little power and I can hear a noise that ain't right.
Any thoughts?
dboll
01-03-2007 05:12:04
 Re: PTO failure in reply to David Lee Hawkins, 01-01-2007 08:42:58
On some of the dry clutch pto's it is common for the clutch forks to be completely worn out with no used ones any good at salvage yards. Eventually they break off so the pto can't be engaged. This happened on my 1550 so I cut the ends off a clutch fork out of a DC Case and welded them in place of the old ones, worked good!
farmritch
01-02-2007 19:03:37
You don't havr to split it if it's a pto shaft pin
luapp
01-01-2007 19:53:16
you should take that little cover off the bottom first. see if the set screw came loose and let the clutches come out. had that happen twice.dont have to split it toput back in. a little feness they will go back in on at a time. if you can have some buddy move the lever for you makes it a little easer. put removeable locktighte on allen screw and put anouther one up behind it and it will stay.
SteveM
01-01-2007 09:30:15
Welcome to the club ! Standard for this tractor. Have fun splitting it apart to fix.
Good Luck !
J Schwiebert
01-01-2007 08:48:27
Your comment: "Any Thoughts" What model tractor? How much "snap" did it take to throw the clutch overcenter before? If it one you should grease, have you? Remember the PTO drive runs anytime the engine runs. Now: Your comments. J.
David Lee Hawkins
01-01-2007 08:46:33
 I have an Oliver 550 in reply to David Lee Hawkins, 01-01-2007 08:42:58
I left the make and model out. I have an Oliver 550. I believe it is a 1960.
Ray C CLARK
01-01-2007 17:19:37
 Re: I have an Oliver 550 in reply to David Lee Hawkins, 01-01-2007 08:46:33
My father and I took a super 55 and a 550 splite them in two rebuilt them. What a wondeful Tractor I'm still useing them If you have any mechanical ability you can Do it! not that difficult. well worth the LABOR....1/1/07
