770 axle question:
DennisWI
12-26-2006 16:48:40
I have a 770 s/n 175 625-021 and it does not have grease fittings on the axle caps. The caps were never drilled and tapped. Do the later 770's not need the bearings greased? Thanks in advance for any help.
DennisWI
12-26-2006 17:42:28
 Re: 770 axle question: in reply to DennisWI, 12-26-2006 16:48:40
Is it a sealed bearing or does it get oil from the rear end? Thanks
J Schwiebert
12-26-2006 18:48:49
 Re: 770 axle question: in reply to DennisWI, 12-26-2006 17:42:28
They are tapered bearings and get oil from the final drives. It might be a good idea to check the bearing endplay. J.
770
12-26-2006 17:23:46
My 1966 does not have grease fittings.
