Question for Mr. Schwiebert
Phil P
12-22-2006 17:51:54
I'm rebuilding a gas engine in a 550 , The only kit's that I've been able to find state 550 up to serial # 72831, That covers the 1958 and very early 59 model . Do you know what is different other than the cu in. 144 vs 155 . I plan on using the over bore 3.75 Kit. As far as I know everything else other that the bore is the same. Thanks
Cockshutt
12-23-2006 06:51:44
 Re: Question for Mr. Schwiebert in reply to Phil P, 12-22-2006 17:51:54
Try Phil Heisey( 216-256-8651)I am pretty sure he will "understand" your question.
J Schwiebert
12-22-2006 19:20:18
Personally, You could not give me one of those kits. I don't understand your question. Later 550 tractors have different manifolds, larger valves different carburetor, etc. Me I would go 3.625 if you are at 3.500. I also sent you an e-mail. Merry Christmas!. J.
tompoplett
12-24-2006 14:43:05
 Re: Question for Mr. Schwiebert in reply to J Schwiebert, 12-22-2006 19:20:18
i posted aquestion on a oliver series a gas that i blew a hole in the side of the block.my question is can i just patch it or should i just try to get another block.
RCP
12-23-2006 03:10:13
J why are so against the 3-3/4" bore kits?
