External Hyd hookup on 550
GHH
12-22-2006 06:19:58
Don't have. Can one be rigged without the original Oliver valve that bolts under seat front. If remove cover where it bolts what will I find? Looking to pull a wheel rake that need hyd power for lift.
Skywalker3
12-22-2006 22:57:12
 Re: External Hyd hookup on 550 in reply to GHH, 12-22-2006 06:19:58
As Mike said below, I have heard of doing it this way. However, I have a 1974 550 and the pressure and return ports are not threaded. They would have to be tapped out to be used. On mine, I run a loader off of the internal hydraulics and it works very well. I have some type of a cessna 'power beyond' valve (which is nothing more than a chunk of iron with ports as described below)that the hoses are connected to. They are then routed to a three spool valve (with internal relief)to control the loader and external hyd hook-up. E-amil me if you want some pics. Good Luck
Mike (WA)
12-22-2006 08:40:40
Brent's reply is on target, but I think there is also a less elegant solution. If you take off the plate, there are several pipe ports- you can plug all but the two front ones, which are one above the other- bottom is the live port, as I recall, and the top is the return. I think they are threaded, so you might be able to just take the plate off, plug the back port (it is the relief valve return when using the OEM external valve) and the little one in the middle, and screw pipe fittings into the two I mentioned, running hoses to a valve (with built-in pressure relief valve), then to remote connectors. "Some assembly required, your results may vary. No warranty, express or implied."
TEXAS OLIVER CONNECTION
12-22-2006 06:43:07
Hi---I have an external hydraulic valve assembly for super 55's & 550's---If interested, shoot me an email---- kgteinc2@flashnet,net ---thanks
kent
Brent H
12-22-2006 06:41:47
I made one for dad's 550. I took a chunck of square stock about an inch and a half thick, and 3 inches square, and mated it up to the side of the transmission cover where the valve would bolt up to. I then marked and drilled the holes about half way through the block for the hydraulic ports, along with scoring the block for orings to seal the block to the transmission cover. I then drilled holes from the bottom and rear of the block to the holes only bored half way through, and tapped them for 3/8 pipe thread, and then just ran hoses to a remotely mounted valve purchased from Northern Hydraulics. It is not a factory set up, but does the job very nicely, and cost about 1/4 of what the original valves are going for on Ebay.
