Oliver 66 smoking??
t.r.y.
12-18-2006 04:27:08
HEllo I've got a 66 that smokes oout the exhaust pipe when warm. eventually it fouls plugs. It runs very good until warm and fouls plugs. I guess I'm looking at oil rings or intake valve seals. Whats the best set to take. take the head off and check it out first and if I find anything fix it and try or just put a set of rings it and valve seals put it back together and try it?? thanks happy holidays
RAB
12-18-2006 11:59:40
 Re: Oliver 66 smoking?? in reply to t.r.y., 12-18-2006 04:27:08
Check your plugs to what type of fouling you have.
May just need a grade hotter plug or the mixture weakening a bit?
Try a compression test first before tearing into a good motor?
Should be able to replace valve stem seals without removing the head?
Check to see which cylinders are giving trouble first?
Regards, RAB
Roger in Iowa
12-18-2006 09:29:01
What is the color of the smoke? Blue or black? Blue is oil. Black is too much gas. Does it use much oil?
Roger in Iowa
T.R.Y.
12-18-2006 16:35:17
 Re: Oliver 66 smoking?? in reply to Roger in Iowa, 12-18-2006 09:29:01
Hey thanks guys for the reply. Its definitely oil. I've been around motors for along time. Just wondering what you'all oliver guys thoughts. I have a 77 apart building an engine for it right now. then next project is the 66. thanks guys I'll post back for what I find. Happy holidays to all. Trent
