Spin on oil for 1955?
Moline_guy
12-14-2006 19:39:29
Was wondering if there is a spin on conversion for the 310 in the 1955 to replace the cloth filter? I just don't like that cloth filter and upside down to boot. I clean the canister good before loosening but it just seems like your mixing dirty oil when you lift off that cloth filter, I thought maybe there is a conversion out there to switch it over to a spin on. Thanks for any replies.
Moline_guy
12-15-2006 20:05:50
 Re: Spin on oil for 1955? in reply to Moline_guy, 12-14-2006 19:39:29
Thanks for all your replies, not sure if I will switch it or not if the sock type is still the better types of filtration, just thought the spin on would be less messy, and less chance of getting dust or dirt in the base when changing. Thanks again.
J Schwiebert
12-15-2006 04:05:03
Dean: Remember the 1955 filter base has the cooler built in, while that 1655 gas one does't or aM I too sleeping this morning? J.
Dean Barker
12-15-2006 16:01:29
 Re: Spin on oil for 1955? in reply to J Schwiebert, 12-15-2006 04:05:03
John, I forgot about that. Thanks e for the information on the Fleetguard filters.
Dean Barker
12-14-2006 20:10:48
I have two 1655 Olivers diesels that I have converted to spin on filters. I used a gas engine filter base. You have to use a plain flat washer under the capscrew that goes into the oil gallery so it doesn't leak oil. If you want to use a larger filter like the Cummins Fleetguard LF3479 you have to change nipples. AGCO charges over $50 for this, so I had one made at a machine shop. I believe there is a conversion where you can use your present filter base also.
Don-Wi
12-15-2006 23:01:23
 Re: Spin on oil for 1955? in reply to Dean Barker, 12-14-2006 20:10:48
That almost sounds like a HAstings number with the LF in front. I always get Hastings fi,lters from the local auto store for my F150, an LF115.
Maybe I'll look it up on the Wix site...
Donovan from Wisconsin
e
12-15-2006 10:20:07
To be honest, the sock style filter (depth type) is not all that bad of a filter as most people think. When I worked at Cummins, they were considered the "cadillacs" of filtration.
If you are buying Fleetguard filters, make sure you buy the ones with Stratapore...the extra cost is easily offset by the increase in filter efficiency. However, the best filter to run is the Fram Toughguard....as of late, very very few other filters can touch it's efficiency and they are not badly priced.
klf
12-15-2006 16:49:26
 Re: Spin on oil for 1955? in reply to e, 12-15-2006 10:20:07
I don't know about the Fram Toughguards, but the regular Frams weren't rated very highly. Was wondering if there were some improvements made. Anyways, the Fleetguard is a good filter.
