marriage of a 1855 and 1850???????????
JD Ogden
12-13-2006 20:14:00
I have a 1855 that was a gasser, it is a parts tractor now. The rear half is pretty much complete. I just bought a 1850 with a perkins in it, pretty much a parts tractor also (it runs). Now to the question can I change the tub and motor on the 1850 to the rearend of the 1855 to make a tractor that has the perkins and the updated hyd. and brakes. I would like any input I can get pros, cons, good, bad or the ugly. thanks JD
JD Ogden
12-15-2006 19:33:02
 Re: marriage of a 1855 and 1850??????????? in reply to JD Ogden, 12-13-2006 20:14:00
Thanks for the info I'll let you know how it turns out THANKS JD
Fred Whittaker
12-15-2006 06:51:04
I have done this conversion myself. It worked very smoothly. A couple of things that you might want to get is a fuel tank bracket for the back of the engine and a throttle linkage from the dash connection to the injector pump from a white 2-105. The 1855 tank sits lower than the 1850 tank, getting in the way if you try to use the 1850 linkage, and the 1855 linkage is completly different. Keep us posted on how it turns out.
MikeOwi
12-14-2006 06:56:27
Did that but basically used the front end of a 2-105 White. Since you would have both tractors, it would be an easier process to mix and match to make it work. I was fortunate to know my Olivers well enough that when I purchased the engine and tub, I asked for some of the other parts I thought I would need. The only thing I didn't get was the tach for the Perkins engine. There is something different between the engines that makes the old one useless.
Don-Wi
12-13-2006 22:11:33
It's 100% doable, and several 18 and 1755's already have been converted to perkins engines. Best part is, you have all the parts to do so on hand. I can't give you any specifics as to what needs to be done, but most of it should be a relatively straight forward job.
Donovan from Wisconsin
