Oliver 550 (I think)
oldoliverlover
12-10-2006 20:48:51
Recently purchased tractor (Model #315-71077 serial # 192890-428) My reseach tells me this is a late 1967 model 550 but tractor is industrial yellow with no decals. Loader has White 2-44 on each side. Transmission is 4 speed w/shuttle. Is the White 2-44 just the loader and should the tractor be decaled as a 550?
oldoliverlover
12-11-2006 10:50:46
 Re: Oliver 550 (I think) in reply to oldoliverlover, 12-10-2006 20:48:51
Thanks for the info - Any easy was to tell difference between a 578 and 588 Loader?
J Schwiebert
12-11-2006 09:30:26
You caught me off guard a little bit. The 2-44 is a basic 550. 44 Is the FLYWHEEL horsepower. There were 2 different loaders used so you can hava a 2-44L or a 2-44LL. The difference is the loader. More questions? J.
rp1555
12-11-2006 06:42:07
At first ,from the 315, I would say it is a 550 ind. I later found that they were designated 2-44 by jan. 1967.I thought it was later
repainted/decaled. I am not 100%sure, but I would say you have a 1967 2-44 tractor,and the loader could be a 588 .The decal has three spaces
the upper left means 2 or 4 wheel drive.Upper right means horsepower.The bottom, if it is a number, means backhoe reach,or L for loader or FL for forklift.If the bottom was blank ,means ind. tractor only.
