oliver engine detriot
dan reed
12-10-2006 18:49:25
can you put a 6v 92 in a 1900 oliver, i have old engine and my tractor is blowed up just thought about using the engine if itll fit? thanks for the info danny
RonLoren
12-13-2006 08:46:57
 Re: oliver engine detriot in reply to dan reed, 12-10-2006 18:49:25
My Dad and I own a Super 99 we pull in the stock classes. Tons of fun. A buddy of mine calls it a diesel converter..... ..It converts diesel fuel to noise!
oliver gets it don
12-13-2006 05:04:03
hey steve you might want to take a math class before you start picking on detroits on here a 8v71 is not a 318 a 671 is and it is in a in line or v i have a inline in ford truck and 4-53s in 1900s and 371s in 99s 990 s olivers and a 371 in a massey 98 there is 3 advantages to those old detroits no1. you can see where you have been no.2they can hear you coming. and most allways pull the load with just a little extra screaming merry x mas to all steve ask santa for a caculator
Steve Gerot
12-14-2006 19:55:52
 Re: oliver engine detriot in reply to oliver gets it don , 12-13-2006 05:04:03
Sorry but 318 was the hp rating.
Ted W.
12-11-2006 22:19:09
I say go for the 6v-92 it won't be longer than the stock 4-53. However I would beef up the frame because some of those 6-92's could crank out 325 plus horses. Have fun.
good6742
12-11-2006 16:48:45
I have a complete 4-53 out of a 1900 if you want another stock engine. Also have the radiator, fanshaft assembly and air cleaners.
Merlin in Saint Louis
12-10-2006 19:47:40
Hello! There is a farmer near Arcadia, Wisconsin who installed a 6V53 Detroit engine into an Oliver 1950. It actually fit pretty well. He needed to grind the frame a little bit near the starter, but not enough to affect the strength of the frame. He runs a forage harvester with this tractor, and really likes it. A 6V71 or 6V92 might be too long for the frame. Merry Christmas, and best wishes on your tractor project! Keep it running!
Merlin
Steve Gerot
12-10-2006 19:23:06
I dont know if it can be done but I would think twice about putting a 2 stoke Detroit in anything. There are a lot better engines out there although they do sound cool.
bradk
12-11-2006 15:32:25
 Re: oliver engine detriot in reply to Steve Gerot, 12-10-2006 19:23:06
Anti-Detroit?WHO IS THIS GUY?(just kidding)
We have 4 Olivers w/Detroits and they're our most prized tractors.Gobbs of horse power and incredible fuel economy and no major engine problems.
I remember about 20 years ago a push rod went bad on a 990 and 2 years ago a fuel pump went out on a 1950FWA.~brad
Steve Gerot
12-11-2006 15:58:09
 Re: oliver engine detriot in reply to bradk, 12-11-2006 15:32:25
Back in the day we had an ole 1970 KW 900-A with an 8V71 (318) non yurbo Detroit and a 13 speed. It had been converted into a tandem dump truck. At 2100 she was running over 75mph. It had an air opperated throttle lock. Not sure if it was supposed to do this but if you were running wide open and flipped that lever it would set you back in the seat. I dont know how much more it would turn but I got it to 85mph before chickening out. With those dual straight pipes and stacks she really cackled.
We also had a Ford dump truck with the turbo version 350hp. Would leave the quarry with 55000 lbs gross. Had a 3/4 mile up hill climb. This ole farmer lived right on top of the hill would be grinning ear to ear when I went past at about 65mph just grabbing high gear.
Problem we had was cracked rings. Some told use we werent running them hard enough. They said before you get in a detroit powered vehicle you should slam your hand in the door.
bradk
12-11-2006 18:02:04
 Re: oliver engine detriot in reply to Steve Gerot, 12-11-2006 15:58:09
That's great!!Drive 'em mad!!
I'm laughing my butt off!!
I do know that they're happiest running at governed wide open.
A retired farmer friend of mine has an older Ford700? with a charged Detroit.He hires other guys to drive for hauling sweet corn and sugar beets.He always gets calls from other truckers that the hired guy is beating the heck out of his truck by racing the engine.
I listen when he drives his own truck away and he really pours the coals to it. Has only had oil leak problems with his.Later bud!
~brad
Don-Wi
12-11-2006 08:17:38
The 1900 and 1950's had a samller detroit in them, a 4-53 if I remember right. Then in the 1950-T they got away fomrt he detroits. They also used detroits in the Super 99 and 990's, and there were 2 oliver-built massey's that were the Super 99/990, and they also had the detroits in them.
He just wants to upgrade to a bigger screamer.
Donovan from Wisconsin
