Cockshutt 1755 fuel pump question
Wade BH
12-07-2006 19:39:05
The engine appears to be running very rich (thick smoke) and uses a lot of fuel. How do you turn the fuel down on the injection pump?
Don-Wi
12-08-2006 13:29:34
 Re: Cockshutt 1755 fuel pump question in reply to Wade BH, 12-07-2006 19:39:05
This might appear to be a silly question, but when's the last time the air filter was checked/replaced? If it can't get enough air it'll over-compensate with a little more fuel.
Just a thought, and it's surely easier than messing with the pump.
Donovan from Wisconsin
Wade BH
12-08-2006 19:16:09
 Re: Cockshutt 1755 fuel pump question in reply to Don-Wi, 12-08-2006 13:29:34
Good question about the air filter, but I replaced all those components, and it appeared that the elements I replaced were nearly new. Hence, the former owner probably tried to fix the problem by replacing the air filter as well.
J Schwiebert
12-08-2006 02:42:42
First of all there is a model number on the pump. How about that full number. Maybe you do not have the correct pump to start with.
Wade BH
12-08-2006 19:18:24
 Re: Cockshutt 1755 fuel pump question in reply to J Schwiebert, 12-08-2006 02:42:42
I suppose that I could not have the corret pump. But, the paint on the pump matches the faded paint on the rest of the tractor and it doesn't appear that the pump fittings have been tampered with. I'll be back at the farm in 3 weeks. I'll fetch the number at that time.
