Oliver 77 axle oil seal
Tracy Redd
12-06-2006 20:19:31
Is the rear axle oil seal is inside the axle(under the seat) or outside ( close to rear wheel hub)? the oil leaks out the axle hub. The oil leaks when parks on small slope and made a mess on the rims.
Thanks
Tracy
J Schwiebert
12-07-2006 03:22:40
 Re: Oliver 77 axle oil seal in reply to Tracy Redd, 12-06-2006 20:19:31
Check your oil level. Do you add a lot of hydraulic oil? We pulled the PTO shaft out of one one time and oil ran out! The seal is on the outside, BUT the seal is not the same for a 77 Fleetline as it is for a Super 77. More questions? J.
Tracy Redd
12-07-2006 09:25:47
 Re: Oliver 77 axle oil seal in reply to J Schwiebert, 12-07-2006 03:22:40
I have check the oil level and the oil runs out oil level plug.I think it got too much oil in it. When tractor sits on level, the oil won't leaks out but if tractor sit on slope oil leaks out. I want put new seal in it Becasue i am fixing start paint the tractor. My 77 is 1950 model and mine is not super 77.
Thanks
Tracy
