Muggy weld rods, Do I dare??
Steve Gerot
12-05-2006 19:12:25
third party image
Ive been checking into lock and stitch pins for the the cracked water jacket on the ole 18-27. Seems the best but expencive and a lot of work. Was all ready to order a kit. Then today I was reading a post on the J.D. forum and they were discussing Muggy weld rods. So far it looks like an option, but Im worried because if it does not work I may not be able to use the pins after. It is supposedly guarenteed not to re-crack and is machinable
Any opinions?
Check out the videos on their site.
fort67
12-06-2006 17:22:32
 Re: Muggy weld rods, Do I dare?? in reply to Steve Gerot, 12-05-2006 19:12:25
Are you a great cast welder? Not trying to be mean here. I'm from the north we would run into cracked castings in blocks and etc. If you find a true blue welder that can weld cast you hardly ever see where it's been welded. We had one we bought with a split down the whole side. He ground and welded back in. when he was done you couldn't tell where the split was. Just my two cents. Key is PATIENCE
george md
12-05-2006 23:05:30
Steve ,
If you weld it and it fails , you will
not be able to drill and tap it . The weld
in the fusion zone will be harder than the
drill and tap. That's why I told you to lace
that crack.
george
J Schwiebert
12-05-2006 19:41:07
Least amount of money go with the Irontite 327 pins. A 327 pin will use a a 1/8 inch pipe tap. Drill a 3/16 inch hole at each end of the crack and see how thick the block is. J.
Steve Gerot
12-05-2006 20:12:12
 Re: Muggy weld rods, Do I dare?? in reply to J Schwiebert, 12-05-2006 19:41:07
third party image
Oh
I was pricing the lock stitch pin kits at a different Co. It was well over $100 for the kit I would need. I will call the kwik-Way Co. tomorrow. They claim that new rod does not require preheat but Im pretty sceptical. I will try to get over there and drill my depth hole in the next couple days
Steve Gerot
12-05-2006 20:52:03
 Re: Muggy weld rods, Do I dare?? in reply to Steve Gerot, 12-05-2006 20:12:12
OOPs
Will call Kwik-Way about their stitch pins. I re-read my post and noticed I had worded it like they sold the rods.
J Schwiebert
12-06-2006 14:03:21
 Re: Muggy weld rods, Do I dare?? in reply to Steve Gerot, 12-05-2006 20:52:03
You are not going to need a full box quanity. I would suggest buying pins some from a shop that does this type of work.
