Oliver 1555 Hyd. Filter
Farmer Ryan fro
12-05-2006 16:15:29
I what to change oils in my 1555 gas, but the only problem is where is the Hyd. filter.
Thanks
Dean Barker
12-05-2006 20:55:07
 Re: Oliver 1555 Hyd. Filter in reply to Farmer Ryan from WI, 12-05-2006 16:15:29
I use a big pipe wrench on the filter body on my 1655's to get them off. When installing the new filter element, coat both ends with vaseline so as you tighten the filter body you don't twist the filter or rip the gasket off of either end. Follow John's advise as to where to find it.
J Schwiebert
12-05-2006 17:48:36
See that cast iron can in the front of the hydraulic unit?. It has a 1-11/16 hex on the end. The filter is inside that cast can.
kkiowa
12-05-2006 18:34:26
 Re: Oliver 1555 Hyd. Filter in reply to J Schwiebert, 12-05-2006 17:48:36
Get a 3/4 breaker bar and about an eight foot pipe,I've seen some of them that were really stuck.
