Oliver 60 Water Pump
Len
12-04-2006 10:56:51
I called Korves to order a rebuilt water pump for my 60, and found that they are no longer selling them. Does anyone know where to buy a rebuild kit or a rebuilt pump? Or should I just try to take mine apart and put in a new seal?
Ron Grother
12-05-2006 02:35:54
 Re: Oliver 60 Water Pump in reply to Len , 12-04-2006 10:56:51
you can have it rebuilt at napa about 120.00
Len
12-06-2006 20:38:24
 Re: Oliver 60 Water Pump in reply to Ron Grother, 12-05-2006 02:35:54
Thanks for the suggestion. Unfortunately, my local Napa tells me that they don't send pumps out to be rebuilt.
J Schwiebert
12-04-2006 11:51:31
This is like a political talk. You can buy a kit, you can also buy a seal seperates. NOW the play on words: If your pump has the new style impeller you can use the new style seal, if you have the old style impeller and seal yet, you need a kit. Those old style seals and impellers were discontinued in the 1960's so now you have the rest of the story. No matter which way you go you will need to resurface the wear surface for the seal, old or new style. More questions? J.
Len
12-04-2006 13:41:15
 Re: Oliver 60 Water Pump in reply to J Schwiebert, 12-04-2006 11:51:31
Thanks for the reply. How do I tell an old style impeller from new style? Who sells kits?
