ever have this happen?
Don-Wi
11-30-2006 10:19:13
I was plowing with the 1855 last Sunday. I got off to talk to my dad quick who was moving a pile of brush out of my way, when i noticed the nuts that hold the injection pump on were jiggling, so I decided I'd go home quick and snug them up.
When I put a wrench on them, the top one fell out and a bunch of oil ran out behind it.... Decided I'd better stop right there.
I called the dealer on Monday and today they came and picked it up. If I had a place inside where I could wokr on the 18 preferably heated, I would have tackled that job myself but I don't like messing with stuff like that (kinda unfamiliar territory for now) outside where I don't have much time to spend on it.
Kinda wondering why the studs would have pulled out of the plate, other than previous guy over tourquing them....
Now my only hope is that we can get it back soon enough before the ground freezes too deep to finish plowing. Only had about 1 1/2 hours left before the mishap....
Donovan from Wisconsin
El Toro
11-30-2006 16:34:28
 Re: ever have this happen? in reply to Don-Wi, 11-30-2006 10:19:13
They may be able to install heli-coils if the threads are worn or stripped. We have a place in Batltimore that only has bolts,nut and studs. He can order them if you know the size of the stud and which thread and the length. You may have one in your area. Hal
Don-Wi
11-30-2006 23:40:28
 Re: ever have this happen? in reply to El Toro, 11-30-2006 16:34:28
They're studs that are welded to the plate on the front of the engine, behind the timeing gears. not enough room for a full bolt or anything like that, and not enough for a threaded stud (maybe 1/8" thick at the most, for a 3/8" stud) I talked to the service manager at the dealer and he said while he has dealt with it before, and he should be able to fix it without having to remove that plate, (would involve pulling the engine) it is a fairly uncommon thing to have happen. I guess that would explain why that side of the block is so black, I just never happend to notice it on Sunday and it's probably been like that for the last 100 or more hours. I'll have to make sure to change the oil once it gets back because it's both in need of it and fuel did get ion the oil from when I started to mess with removing the gear that drives the pump to have a look at it. Once I saw what was involved I buttoned it back up and called in someone who knows what they're doing because we need it back pronto and its ^%#(&%^ cold outside!!!.... Way too cold for me to want to repair anything like that.... Funny thing is, it was in the 50's on Sunday when the problem began....
El Toro
12-01-2006 04:15:46
 Re: ever have this happen? in reply to Don-Wi, 11-30-2006 23:40:28
It was 71 here on Thurs, but that is suppose to change today. Your cold weather is moving toward us. Our neighbor ran Olivers, we had Farmalls when I was on the farm. Hal
CumminsMan
11-30-2006 10:40:25
Yeah, it would be nice if a guy could get those studs. Dad had one twist out last time we had the injection pump off on the 1755. He just pulled the pump, took the timing gear off and welded the old one back in.
