310 d piston
o
11-29-2006 17:58:05
how low should a piston been in a liner from the top of liner to start with at tdc,1969 1750 oliver diesel,milled top of block .008,line honed mains,did counter bores,recondition rods with one pcs. bushing and bolts with washers also are new ones from agco 3/16 shorter,milled head .018,all new valve seats,valves,spring and guides. with block being milled .008 and all liners up above block.003,ex valve up .041 and intake up .029,will it be ok and not hit ,just thought i would ask for everybodys thought
J Schwiebert
11-30-2006 02:58:01
 Re: 310 d piston in reply to o, 11-29-2006 17:58:05
At TDC what is your piston height in relation to the top of the block? Were the rods bored to center distance when the rods were reconditioned? Did they do the big end of the rod too? Tolerance on the rods is plus or minus 2. I don't have the dimension you need but if it was me I would take the old head gasket, find the highest piston and a couple of pieces of solder. Lay the solder on top of that piston where th valves would open, put the old head gasket on, torque the head to about 75 pounds and turn the engine over a couple of times, take the head off and measure the height of the solder and see where you are at. Then you have some measurements you can work with. Remember also the pistons will expand and this clearance will be less than what you measured. We had to do that on a Moline once and we were at the minimum and it ran good until you put it on the dyno and put it at rated power for about 45 minutes. Then it "ticked" Sorry I can not be of more help. J.
