restoring Oliver RC88
Brad V
11-29-2006 12:57:40
I'm just getting started on my project, I have to replace pressure plate and throw out bearing, so as long as I have the hood, console, gas tank off i figured I may as well keep going and do it up right. Last night I was trying to take off the fenders and broke a bolt off, theyre all on pretty tight so I would imagine I'm gonna break more off. I'm wondering...Should I remove the rear wheels now so things are more accessible, and I'm gonna need to paint the wheels anyway so will need to have tires taken off the rims correct?
This is my first restoration project so I'll need more help down the road, any advice is appreciated.
El Toro
11-29-2006 16:17:03
 Re: restoring Oliver RC88 in reply to Brad V, 11-29-2006 12:57:40
If you have an acetylene/oxygen torch I would try some heat on those bolts. Hal
ACEd(La)
11-29-2006 15:26:35
As to removing tires - that depends. If tires can be removed without damage or if you are going to replace anyway (deep pockets) then yes - take them off. But if they are in good shape but old and been on a long time odds are more likely that you will damage one or both or pinch a tube and end up regretting it. If they are matched and holding air well, I personally would not mess with them other than to get fluid out if they are loaded. Several options to mask for painting including tape and paper for gross coverage with a mastic or similar or even caulking RTV or have heard Vaseline - something that can be cleaned up next to rim.
ACEd(La)
11-29-2006 15:25:48
