PTO clutch 1365
Rob NC
11-28-2006 19:48:13
How and when to use the pto clutch,and what posistion it should be in when the pto is not in use,I dont have the manuals I need yet.
Marc Smothers
11-29-2006 16:16:58
 Re: PTO clutch 1365 in reply to Rob NC, 11-28-2006 19:48:13
Hello.. Use the pto clutch to engage/disengage the pto. When the pto is not in use the clutch lever should be down(engaged). This helps to prevent premature wear on the engine thrust bearing..... Very good tractor you have there... Marc
Rob NC
11-29-2006 16:52:32
 Re: PTO clutch 1365 in reply to Marc Smothers, 11-29-2006 16:16:58
Thanks Mark,This is my first real tractor,I started out with a locked up Cub that was given to me.Traded it of on a 8n. For 800.00 bucks & the n,I got the Oliver.Ill try to post some pics later.
