Cockshutt 50 Distributor
W. Keitel
11-28-2006 06:08:10
273 Buda engine and the distributor is wore out. Can't keep the points set. Do I need another distributor or can the one I have be rebuilt with out to much trouble?
john barendregt
11-28-2006 22:02:49
 Re: Cockshutt 50 Distributor in reply to W. Keitel, 11-28-2006 06:08:10
i have a cockshutt tractor i dont know the make or model it has a 6cyl diesel it has high and low range on the one shift stick 3 on top 3 on bottom throttle on same shaft as steering wheel it has pto but no 3pt hitch
Hard Knocks
11-28-2006 16:56:08
As Error 5 said get rid of the Autolite and get a Delco distributor.
550Doug
11-28-2006 07:49:59
Now is the time to make the switch to Pertronix. Get the model number off of your current distributor and get the right Pertronix. I switched my 550 last year with the Pertronix 1142 kit and the non-vibration coil (40000 v) and the tractor runs so much better, and it will even idle slower than manual specs!!
Good luck
W. Keitel
11-28-2006 08:28:27
 Re: Cockshutt 50 Distributor in reply to 550Doug, 11-28-2006 07:49:59
Is there a web site? Who do I contact? Thanks for the info. I have an Auto-lite IAD 6001-1B 3k
distributor now.
550Doug
11-28-2006 16:54:44
 Re: Cockshutt 50 Distributor in reply to W. Keitel, 11-28-2006 08:28:27
According to my listing, the IAD-6001-1B will need the Pertronix #1561-P6 for a positive ground 6 volt system. However I would confirm with Pertronix at 909-599-5955 or talk to Bob at Performance Automotive in TN at 239-728-2810.
Make sure that your distributor is in good condition.
Good luck
Error 5
11-28-2006 13:25:02
get a delco out of a gleaner 262 will fix your problem.Pertronix Ignitor pt #1166 for the Delco Distibutor
