Oliver Super 55 clutch shifting problem
Joe Klaudi
11-26-2006 16:38:26
I have an old Super 55 that will not go into gear without grinding. The clutch also fails to disengage must of the time unless the brakes are applied. can anyone offer any suggestions??
J Schwiebert
11-27-2006 18:24:07
 Re: Oliver Super 55 clutch shifting problem in reply to Joe Klaudi, 11-26-2006 16:38:26
First of all how much free travel do you have? How much wear in the linkage. Is it gas or diesel? Do you have the idle speed adjusted properly? It could also have a bad pilot bearing/ Start there and get back with us. Questions? J.
Joe Klaudi
11-28-2006 14:52:46
 Re: Oliver Super 55 clutch shifting problem in reply to J Schwiebert, 11-27-2006 18:24:07
1) There is 1/2" of free travel on the pedal.
2) There is minumum wear in the linkage.
3) Gas
4) I have nio idea what the tractor is idling ar (I am also looking for a replacment tach cable) but I have it throtled down when attempting to shift.
5) I guess that leaves the pilot pearing as the only logical explanation?
jake4
11-27-2006 17:41:47
The tractor transmission is not designed to be shifted while moving, place in the gear you want to use and leave it there.
Joe Klaudi
11-28-2006 14:47:31
 Re: Oliver Super 55 clutch shifting problem in reply to jake4, 11-27-2006 17:41:47
The grinding is when the tractor is stationary. I am aware that the tractor cannot be shifted on the move.
