548 white plow help please!
Obsession
11-26-2006 09:23:12
Can the 1st bottom on a 548 4 bottom 18" plow be removed, so that it can be used a s a 3 bottom.
I measured the front hitch and there is enough room to move the hitch over exactly 18 inches.
I have a manual for an old 565 plow and it can be done on that plow.
I also have a manual for a 588 which says nothing about removing the front bottom.
I have not found a 548 manual yet. I have been watching e-bay.
Thanks in advance.
Don-Wi
11-26-2006 13:42:52
 Re: 548 white plow help please! in reply to Obsession, 11-26-2006 09:23:12
There is a little more to it than just moving the hitch bar over, but I see absolutely no reason it can't be done. You'll need to adjust the whole center of draft on the plow or else it'll pull crooked. Look in the manual for the 565 for how that has to be adjusted for the different #'s of bottoms and widths.
I'm not familiar with the 548, but we own a 546 4-16 and a 565 3-16
Donovan from Wisconsin
Randy as in Randy-IA
11-26-2006 12:51:58
Hi , If you are interested you might get a reprint or possibly a original manual from the Floyd co. museum . Call them at (641) 228-1099 and see what's available .
