super 88 clutch replacement
JD hauler
11-24-2006 21:32:33
I am looking to put a new clutch into my super 88, any input into the best way to do this is appreciated, I heard you dont have to pull the motor, just slide it ahead and unbolt the bell housing, and I have heard you have to pull the motor, any input here is appreciated.
Mike in MI
11-26-2006 19:55:35
 Re: super 88 clutch replacement in reply to JD hauler, 11-24-2006 21:32:33
If you don"t have the belt pully unit or a power booster on your 88, you can change it without pulling the engine. Just remove the hood & fuel tank and remove the PTO shaft, Steering arm, clutch rod, throttle linkage an may need to unbolt the four bolts that holds the dash and lean it back toward the seat if you need more room?. Unbolt the and slide the couple on the clutch shaft toward the transmission main shaft. Using a long socket exstentions to get to the bolts under the bell houseing. Once the bolts are removed slide the clutch shaft back toward the transmission shaft as far as it will go then slide the bell housing out at the same time picking up of the tail of the bell housing as you slide it out holding the clutch shaft while doing this. Worked for me when I changed the clutch on my super. Good luck! Mike
Dave Sherburne NY
11-25-2006 16:10:31
You can get it out without pulling the motor or
sliding the motor forward. You remove the dash [disconnect the steering , wiring, and who knows what else,lots of stuff]. then take the dash off.once you get this far the rest is easy. Its right there in plain sight. DON'T FORGET TO PULL OUT THE PTO SHAFT EITHER WAY YOU DO IT. If you have an engine hoist it may be easier to take off the sheet metal, radiator etc. and pull the engine.Without the hoist, take off the dash. Like the other post said,get a manual. I have access to the factory one .Don't know how good the IT manual is for this job.
El Toro
11-25-2006 12:14:22
You need to get a good shop manual for your tractor. It will give a step by step procedure.
Some clutches in the red tractors can be replaced without splitting the tractor or moving the engine. It will be money well spent unless someone on here has a manual or has changed the clutch in the 88. Hal
