turbo
jackpots2655
11-23-2006 20:05:29
how about it,i have a 2655 the oil pump failed this spring.would like to up grade to an external pump.also would like to fit it with a turbo charger.dose anyone know where i can find some used parts thks scott
g 1355 puller
11-30-2006 18:26:04
 Re: turbo in reply to jackpots2655, 11-23-2006 20:05:29
Unless you put a bigger pump on it the turbo won't do you much good. Put a turbo on my 1355 and didn't do much good until I put a P pump on it and now getting near 500 hp.
Moline_guy
11-24-2006 15:26:01
There should be external kits in most salvage yards, especially in the midwest, call around I am sure one of them has one, I have seen a lot of 585's in the salvage yard here in north central south dakota. Dad has three tractors with 585 and all have the external swicth, never had a problem with these extenals. As far as the turbo, unless its just for show I would say don't do it that engine has enough trouble with out throwing more fuel and air at it, just my 2 cents, good luck whatever you decide.
Kruse
11-24-2006 05:56:07
You have found one of the weak areas of this tractor....the oil pump. I have a neighbor who specializes in MM equipment. I think he has found a way to fix this problematic area, but it"s not cheap.
His advice to having a turbo on this motor? "Don"t even bother".
Larry from md
11-24-2006 15:01:03
 Re: turbo in reply to Kruse, 11-24-2006 05:56:07
I agree and The external oil pump causes as many problems as it fixes. Be sure to use a check valve in the sucktion line.
