Oliver 1600 generator to altenator swap
Jeffrey A. and
11-23-2006 06:23:11
I am having trouble keeping the battery charged on a Oliver 1600 and want to switch the 12V generator over to an altenator also illiminating the regulator. Is there kits available to do this, and if so where. Thank's for the help. Jeff Shelley
J. Schwiebert
11-25-2006 09:38:32
 Re: Oliver 1600 generator to altenator swap in reply to Jeffrey A. and Deborah K, 11-23-2006 06:23:11
It is your tractor and your money, but you may be better oof checking to see why your generator does not charge the battery. I also sent you an e-mail. I have a troubleshooting chart for your charging system I can e-mail you once I have your e-mail address.Questions?J.
oleblu
11-23-2006 17:37:58
I did the exact same thing to my 1800 gas about a year ago. I used a one wire alternator with an internal regulator (for ease of wiring). With the "one wire" you just run a #10 wire from the alt to the positive cable on the battery (either at the batt or the starter). I then just taped the original wires (individualy) to the main wiring harness. The mounting of the alt is a bit more tricky. You will either need to do some measuring (so the pulley lines up) and weld up some brackets OR there is a kit available with flat stock with multiple holes and 90 degree angle pieces that can be made to fit most any situation. E-mail me if you need more info.
