Plastic Fuel Tank Repair
gas2
11-21-2006 17:17:35
Has anyone successfully repaired a crack in a plastic fuel tank (gasoline). What kind of glue, resin, or JB Weld? THANKS!
spud
11-21-2006 19:02:11
 Re: Plastic Fuel Tank Repair in reply to gas2, 11-21-2006 17:17:35
I've repaired many plastic tanks be it in a lawn mower, chain saw, ect. The best thing on the market is a product called PC7. It comes as a two part compound in a paste form. You mix equal parts of each, smear on with putty knife. Make sure surface is clean before application. Gas and oil doesn't bother it. Dries after 24hrs hard as a rock. I use it all the time for many applications. Give it a try.You can buy it at most automotive parts houses or most hardware stores.
