White 125
Leob
11-21-2006 16:00:08
I am looking at a White 125 workhorse fwa. It has 5100 original hours on the cummins motor. Would this be considered high hours on this motor? At what hour range do these motors peak out? How costly to overhaul?
Thanks for any advice.
RRR
11-23-2006 11:17:11
 Re: White 125 in reply to Leob, 11-21-2006 16:00:08
HI there just wanted to let you know oil SHOULD be changed every 100 hours. The 125 in question is a good tractor with one slight weakness....the park lock...like all the whites with that style shifting. This is only a problem if jammed into park while still rolling fast. As far as the engine goes 10,000 hours is nothing and if it were mine when the time comes to repair it I would check into the re-man engine program from CUMMINS. I have worked on these tractors for 15 yrs and have great knowledge of them.
Ron
Leob
11-22-2006 16:24:49
Thanks for the info. I am looking forward to getting this tractor. It appears to be well maintained. Does these tractors have any weak points?
e
11-22-2006 09:31:42
I'd look at it this way, that engine will have only needed at most 10 oil changes to date. In reality, the oil changes could have been stretched to 750 and it still would have been ok.
If you have to touch that engine before 10,000 hours, I would be very supprized unless it was abused. With good care, it will last well over 10,000 hours.
Luke S
11-22-2006 06:28:11
If that engine has had even the slightest of good maintenence, it should be good for a few thousand hours yet.
j meyer
11-21-2006 19:33:24
Sounds like you found a top-quality tractor there. You should have a good 8,000+ hours on that tractor before you should have to worry about a re-build, considering if it had good care. We got a 145 here last winter with 1500 hours on it, and its extremely nice for tillage and such. Its not as handy on the round baler, but thats the way it goes. Very nice tractor, and its still a WHITE!
CumminsMan
11-21-2006 16:19:26
If the tractor looks to be in good condition, not all beat to heck, and has had routine maint., then 5100 hrs is nothing to be concerned about at least on a 5.9. They aren"t that expensive to rebuild, no worse than anything else.
