oliver super 55 or 550 ? which is best and why ?
Scot r Maxwell
11-20-2006 14:32:49
I'm struggling with decision to purchase a oliver super 55 or 550. I really want a super because of it's style, but I've been told the 550 is much better. What's your opinion? Pros and Cons. I would like to use the tractor in construction, but to remember my grandfather as I was raised by him on a farm (his son, my father had passed due to cancer) and he was a pure olie man. I'm going to find a front end loader. What year is the best ? What should I look out for on either super 55 or 550? Any and all comments extremely appreciated and welcomed !! thank you, a wanna be oliver man!
scot r maxwell raised in north missouri by claude maxwell
Farmritch
11-21-2006 19:47:06
 Re: oliver super 55 or 550 ? which is best and why in reply to Scot r Maxwell, 11-20-2006 14:32:49
550"s are of course better (upgrades more hp. etc)
BUT don"t know how hard you want to work it Don"t put a loader on a 550 or a 55 without the non adjustable front end
I just read a factory paper that said this and broke a spindle this spring on mine The light duty adjustable axle has 5/8 axle bearings and will snap if worked too hard Heavy axles are a lot easier to find if you want to add one I know a yard that has 3 near me but no one is interested in the heavy front ends as they seem not to need as much attention as the lighter ones Also power steering is almost a necessity if you put a loader on one I"d look for a 2-70,2-105 or something in the 60-100 Hp range if you plan on working it too hard Just my $.02
Farmritch
Scot
11-21-2006 20:11:58
 Re: oliver super 55 or 550 ? which is best and why in reply to Farmritch, 11-21-2006 19:47:06
thanks for that heads up! i won't be working it all that often and probably pretty light. what's the number of the yard. there is a industrial front end on ebay i'm looking at. 165.00 just for shipping. when you reply 2-70,2-105 what are you refering to? again, thank you very much for your $.02 ! scot r
1755
11-22-2006 18:35:25
 Re: oliver super 55 or 550 ? which is best and why in reply to Scot, 11-21-2006 20:11:58
A 2-70 White the same as a oliver late 1650 and the 1655 2-105 White is about the same as a 1955 oliver with a turbo Pirkins
Scot
11-21-2006 16:48:26
I want to thank you for all the replies! I'm definitely looking into the industrial front end for strength. I know this sounds bad, but I think I'm going to buy a 550 and change the nose and hood to a super 55, I just love those old looking supers! If someone reads this, is desiel better, engine last longer ? Pros / Cons ? thanks again !! scot r
Super 55
11-20-2006 20:44:37
If you are going to work this tractor in construction, I would definately get power steering and you are more likely to find that with a 550. Also, if you were thinking diesel, there may be more diesel 550s than Super 55s also. Maybe you can find an industrial model, with the heavier front end. Do you need the three point?
Matt Kane
11-20-2006 17:24:43
My super 55 had a later 550 diesel engine installed in it and rebuilt. Its will pull pretty good. If you get a Super 55 don"t get one of the first ones unless the hydraulics have been upgraded, they tend to bring air into the system. As of a front loader, A Super 55 front axles arent very tough for heavy lifting. Maybe look for an industrial which has a solid front axle, not adjustable. The swinging drawbar is great if you need to pull anything, if you are close to a hookup, then just pull the pins and swing it where you need it. As far as the 550 they of course contain a different body, and a few things were upgraded. I don"t know if there is a huge difference between the 2 as far as power and such. Either is a good little tractor. I love my little Super 55. Also some contained the remote hydraulic hookups. Good Luck!
John P.
11-20-2006 16:21:44
Other than styling and a little more power with the 550, they are pretty much the same. The hydraulics on 550s and later 55s are a little different than on earlier 55s (I like the older version because you can still buy filters anywhere for them, where the later filter is only available through AGCO). Also the early 55s are harder to find a swinging drawbar to fit them. The very early 55s had a different seat. All of them are good tractors. If you want to use a loader you are best to get one with power steering.
