oliver dozer model?
ole frank 44
11-19-2006 12:39:33
I have an oliver dozer that has an ixb3 engine. where would i find the serial number? im not sure on the model. thanks ole frank.
J Schwiebert
11-19-2006 15:31:16
 Re: oliver dozer model? in reply to ole frank 44, 11-19-2006 12:39:33
It can also be an OC-4 four cylinder. J.
MikeS55d
11-19-2006 14:30:22
That would be a HG / OC3. The data plate for the motor would be on the right side of the block behind the carb. The tractor serial # is on the rigth side of the bellhousing above the frame. Years for serial #'s can be found at the left side of this page.
The most info is at:
http://www.cletrac.org/
