Oliver 70 Sleeve dimensions
Jim Tierney
11-18-2006 13:23:10
Does anyone know the diameter of a 70 sleeve where it seals in the block? Thanks in advance.
El Toro
11-21-2006 10:01:04
 Re: Oliver 70 Sleeve dimensions in reply to Jim Tierney, 11-18-2006 13:23:10
I couldn't find the diameter of the 3 1/8" sleeve, but I did get the diameter of the new 3 1/4" sleeve that is 3.522". I found new sleeve kits for 70 too. Hal
Jim Tierney
11-21-2006 15:15:53
 Re: Oliver 70 Sleeve dimensions in reply to El Toro, 11-21-2006 10:01:04
Thanks for the information.
El Toro
11-21-2006 17:30:36
 Re: Oliver 70 Sleeve dimensions in reply to Jim Tierney, 11-21-2006 15:15:53
You can try Foley Engines too for a sleeve kit, but you will need the model and serial numbers from your engine. They sell Continental engine parts. Hal
1-800-233-6539
J. Schwiebert
11-19-2006 15:34:31
Do you want the diameter in the block or the pilot diameter of the sleeve? Give m a couple of days and i can get you within a couple of thousands. 3-5/16 might be too small since those sleeves can be bored out to 3.250 faily easily. J.
Jim Tierney
11-20-2006 05:21:46
 Re: Oliver 70 Sleeve dimensions in reply to J. Schwiebert, 11-19-2006 15:34:31
Thank you - the dimension of the block where the o-rings seal would be ideal.
El Toro
11-19-2006 05:35:48
That sleeve should measure 3 5/16" in that area. That's if the engine piston's has the 3 1/8" bore. Hal
