Oliver 1250 Starter Problem
Greg Cavill
11-14-2006 08:07:34
I have a 1250 which keeps eating up starters. It is sheering the armature shaft. Currently I am pulling it started until I figure out the root cause. I was told it could be the ring gear. Any advice how to figure this one out without having to split the tractor in half?
ADB
11-14-2006 10:09:47
 Re: Oliver 1250 Starter Problem in reply to Greg Cavill, 11-14-2006 08:07:34
I'd check for something wedged between two teeth of the ring gear (ie a tooth from the old starter). It could shear the shaft when it comes around with the starter engaged. You could check through the starter hole while inching the flywheel around.
