oliver80
Bergy60
11-12-2006 09:00:39
Found a oliver 80 wheatland tractor with motor tore apart looks to be all there but engine is pretty rusty, Wondering if any chance of finding rings & bearings & gaskets for this engine?
Ken L.
11-12-2006 11:20:34
 Re: oliver80 in reply to Bergy60, 11-12-2006 09:00:39
The easiest parts to get that you are looking for are the gaskets. Olsen's Gaskets have individual gaskets or a complete set. Good people to deal with. J.Schwiebert is correct on the rod bearings. They are poured babbit bearings. There are a few places that still do that work. I don't remeber if the mains are poured or replaceable liners. J.Schwiebert is also correct on the rings. There are used parts available. If your not in a big hurry, just keep asking around and watching. They will turn up. Over the last year, I have found nice sleeves, pistons, rods, one has not been used since a new babbit job, I also have quite a few (extra) parts that I may need. I have an 18-28 standard and two 80 row crops. If yours is an HC, the pistons should be 4.25" if it's a KD, they should be 4.50". The heads are also different. Good luck. If I can help let me know.
J Schwiebert
11-12-2006 13:33:17
 Re: oliver80 in reply to Ken L., 11-12-2006 11:20:34
I also have some head gaskets. They are a little different they were experimental for a hopped up 80 pulling tractor. On the poured bearings, the best way to fix that is to take some shims out find someone who does overhead aluminum car heads or industrial engines and have them bored. Questions? Find me on the HPOCA form.
J Schwiebert
11-12-2006 10:13:56
Never had one apart, but didn't the 80's have poured bearings? On the rings what size rings do you need? Remember H C and K D engines were different bore sizes and there is no reason you could not put the larger bore K. D. sleeves and pistons in an H. C. engine If I were looking for rings for that or anything else with a little age to it. I would measure up what I needed and then go to the size chart in a ring catalog and not go some much by application. More questions? J.
