Loader for Oliver 1955
MikeOwi
11-10-2006 19:02:40
Looking for a good loader to fit my Oliver 1955. Just missed out on an 1810 that was sold. Does any one have a picture of an 1810 loader? Also what other loaders would easily fit this tractor? Thanks in advance
dustin braun
11-10-2006 19:15:00
 Re: Loader for Oliver 1955 in reply to MikeOwi, 11-10-2006 19:02:40
I am from northcentral south dakota, and Du-al brand loaders are popular in this area. The model 3000 and 3100 are made for 80-150 hp tractors. I have a 3000 dual on my 1955. Both models are quick attach and can usually bought in good condition for around 1500-1800 dollars with a grab fork on. They slip on and off in a couple seconds once you unhook your hoses. I use an electric valve multiplier because my oliver only has two remotes. Loader is light but strong and works well on the 19. Doesn't interfere with cab or anything else. These loaders are all the same, just need to find mounts for 1750 through 1955 series olivers, good luck. Also if you have never had a loader on yours, I would recommend welding brace irons from spindle supports to axle tube, never broke mine just helps stregthen the front end a little bit.
