Injection Pump Timing
oliver12
11-07-2006 20:00:39
third party image
I am having some troubles trying to time the injection pump on a '54 Super 88 Diesel. It is the round head style Bosch pump. I have a shop manual and parts manual, but my question concerns the drive hub that attaches to the splined shaft. On the drive hub, it has the round part with all the different threaded holes for the gear to bolt to and the drive hub has the flat piece on the back of it that goes agaisnt the bearing retaining plate. Is the timing mark located on that flat piece and should that flat piece be attached solid to the rest of the drive hub. Mine is not attached to the drive hub and I am having trouble finding the timing mark. Any insight from anyone who was any info would be appreciated.
Matt Kane
11-08-2006 13:29:56
 Re: Injection Pump Timing in reply to oliver12, 11-07-2006 20:00:39
I had the same issue on my Super 55 Diesel. I had to look deep into the hole. I found it when the timing was close. Its there, It took me about 6 times to find mine.
J Schwiebert
11-08-2006 03:59:05
I sent you an e-mail. Let me know if you do or do not receive it. Also do you have the splined drive shaft as per illustration? Not all were splined. J.
oliver12
11-07-2006 20:02:14
third party image
Here is the picture
oliver12
11-07-2006 20:01:52
third party image
