S88 Diesel Cold Weather Starting
chris
12-01-1999 18:00:23
It looks like I'll need to start my S88D quite often this winter,and I dont want to use the short cut to an overhaul in a can. Is the intake heating element a reliable way to start a cold engine? Or is a oem or aftermarket coolant heater a better option? My heating element needs rewired with a new switch, then I still dont know if the element works or not. If there is a coolant heater made for it, I may go that route instead. Our winters dont spend much time below 0, mainly around 15 - 20 average. Thanks for any help.
Paul Stanley
12-03-1999 16:42:24
 Re: S88 Diesel Cold Weather Starting in reply to chris, 12-01-1999 18:00:23
Just to let you know how I start my engine in the winter, I have a Super 55. I have an inline water heater in the lower rad hose. I plug it in about an hour before I start it and use the preheater,thermostart, much like the posting below. Works fine. If you can put your hand on the block and it feels warm you know it's going to start. My engine is due for a rebuild in the future, so if mine will start when it's cold a strong one will, for sure.
WFE
12-03-1999 16:05:18
The heating element in the intake manifold, if in working condition, is an excellent starting aid. Experience will teach you just how many cycles and for what duration your engine requires at specific temperatures. But I've never had a starting problem when I do the following: Switch "Thermostart" (Oliver's name for this device) on for a 20 second cycle. Crank engine for roughly 3-4 seconds. Repeat with another 20 second cycle. Crank 3-4 seconds. Finally, give another 15-20 second cycle and attempt to start the engine. As mentioned, your requirements may differ given engine condition and temperature. At about 20 degrees, you may only need 2 cycles. Experiment. But once you get the hang of it, it's more convenient than in-line coolant heaters and block heaters. Good Luck.
GeezerMn
12-02-1999 08:17:49
OEM heater was a special elbow & element for lower rad.hose. You might find a used or new one.1 1/2 inch diam.(memory?) or use aftermarket type in the vertical lower hose. They work ok but not great,takes some lead time. Keep the batterys clean & charged.OE charging systems dont do a good job in cold weather & short runs.Use winter grade oil.
Dave Neubert
12-01-1999 18:31:00
The manfold heater wont help much if the engine is tired but a easy to check it is to disconect the wire from the glow plug take a test light and hook the clip side of the light and hook it to the hot side of the battery.Toutch the probe side to the terminal on the glow plug if the light lights it is ok. Coolant heaters work well if pluged in long enough.
Red Man
12-01-1999 18:22:34
You need a block heater that goes in place of a freeze plug or a tank type heater to get the coolant warm. This makes it much easier on the engine as far as starting and wear. The manifold pre-heater only heats the air in the intake.
