Oliver Hart Parr
Steve Gerot
11-04-2006 13:20:57
third party image
Im looking at an Old Oliver Hart Parr. Im guessing early 30's. It is pretty rough. No cover over the exhaust. The only good thing is it is complete. I cant decide if I should keep it, Put it on ebay, part it out, or run away. It is only 2 blocks from my shop. If you email me I can send larger photos or you may be able to blow these up.
Give me your opinion.
Wingate
11-04-2006 14:27:02
 Re: Oliver Hart Parr in reply to Steve Gerot, 11-04-2006 13:20:57
Wish I lived closer. I sure would be interested in it.I'm in Carson Va.My 18-28 needs a lot of parts before she'll ever live again.
Ken L.
11-04-2006 11:33:06
Mn Dave is right, it is an 18-27
Mn Dave
11-04-2006 16:40:27
 Re: Oliver Hart Parr in reply to Ken L., 11-04-2006 11:33:06
Ken, it can be confusing with all the numbers of those early Oliver Hart Parr tractors, 18-27, 18-28, now which is which, and then trough in the 28-44, 80, 90, 70, if you are not used them it gets intense. I have owned and restored them all so I am familiar with them.
Wingate
11-05-2006 07:16:46
Steve What does the tag behind the Magneto have on it? That alone will tell you what it is. The brakes on that tractor look just like a Oliver 80 rearend I have
Steve Gerot
11-04-2006 12:04:59
 Re: Oliver Hart Parr in reply to Wingate, 11-05-2006 07:16:46
Im in Iowa City
Wingate
11-04-2006 19:45:38
I have a 18-28 wide front and need parts. Where are you located.
Mn Dave
11-04-2006 18:09:54
Steve, again, it is an Oliver/Hart Parr 18-27 Row Crop, built somewhere between 1934-1937.
Ken L.
11-04-2006 16:40:54
It is an 18-28. The Hart-Parr cast into the side of the block, the small radiator tank, and the PTO-pulley lever pretty much tells me that it isn't an 80 and it is deffinately not and 18-27.
