PTO speed change for my 1555
Larry NE IL
11-04-2006 12:14:01
My 1555 has a 1000 rpm PTO. Can I remove the PTO shaft and turn it around for 540? What do I need to change it?
Thanks for the help..... ...Larry NE IL
Wayne in Pa
11-04-2006 15:53:08
 Re: PTO speed change for my 1555 in reply to Larry NE IL, 11-04-2006 12:14:01
You'll need the 540 RPM PTO shaft. To change the speed of the PTO shaft you take the snap ring off and pull the 1000 shaft and insert the 540 shaft. You may need to turn the shaft to get the splines to line up to pull and again to insert the other shaft. I understand some of these tractors had only a one speed PTO eater a 1000 or 540 RPM PTO. If you take the shaft out and look in you should see two sets of splines this would be the setup for a two speed PTO.
Hope this helps, Wayne
Larry NE IL
11-06-2006 14:01:01
 Re: PTO speed change for my 1555 in reply to Wayne in Pa, 11-04-2006 15:53:08
Thanks for the info Wayne!
Larry Coltrin
