Oliver 66 Oil Pressure
Ohiohills
11-02-2006 19:47:09
Tractor is a 1950 Oliver 66 rowcrop. When the engine starts the oil pressure gauge shows some pressure immediately; however, after running a short time - maybe a minute or less - the oil pressure gauge slowly rises and eventually fully pegs to the right. Tractor runs fine. I guess that too much oil pressure is better than not enough, but I"m concerned that this may be indicative of some other problem. Any thoughts or suggestions? Thanks!
tom upton
11-03-2006 14:21:10
 Re: Oliver 66 Oil Pressure in reply to Ohiohills, 11-02-2006 19:47:09
If its a stock guage that sounds normal. Most of my fleetlines peg the oil guage right after start up. These guages must be like 0 to 20 psi?
Ohiohills
11-03-2006 17:25:29
 Re: Oliver 66 Oil Pressure in reply to tom upton, 11-03-2006 14:21:10
It does appear to be the original oil pressure gauge. It"s reassuring to hear that your Fleetlines appear to have the same oil pressure characteristics. Old below has a good suggestion though, I may try another gauge with actual psi pressure graduations just to see what the pressure actually reads when the existing gauge pegs. Thanks for the info!
old
11-02-2006 20:01:51
First off I would try another gauge on it to make sure its not a problem with the gauge. Now if a new gauge does the same thing then you might have a problem with the relief valve in the oil pump, if it has one. I don't know that tractor well but on most engines that is what would cause that type of problem. I know years ago I had a Chev Vega that had that happen and it would blow the oil filter seal in about 30 seconds
