Compression test for Oliver 550
Ivan Pavlovich
08-18-1998 09:31:53
I was wondering what the specification is for the compression of my 1960 Oliver 550. It has a 155cu gas engine. I have measured 160 for all 4 cylinders give or take 5lbs. I measured the compression after putting a teaspoon of oil in each cylinder and it went up about 10lbs in each. Any thoughts or specifications on this would be appreciated. Thanks Ivan
mm
08-19-1998 18:53:59
 Re: compression test for Oliver 550 in reply to Ivan Pavlovich, 08-18-1998 09:31:53
: I was wondering what the specification is for the compression of my 1960 Oliver 550. It has a 155cu gas engine. I have measured 160 for all 4 cylinders give or take 5lbs. I measured the compression after putting a teaspoon of oil in each cylinder and it went up about 10lbs in each. Any thoughts or specifications on this would be appreciated. Thanks Ivan Your engine has exellent compression. The uniformity of the compression says all the cylinder are in equally fine shape. The compression reflect the engine "thinks" it has over a 10:1 compression ratio. 160 divided by 14.7 = 10.88:1. With only gaining 10# by adding oil to the cylinders I would not be concerned by the rings leaking.
MM
