Oliver 66 PTO
Ohiohills
11-02-2006 04:51:21
I have a 1950 Oliver 66 with a damaged PTO. The stub shaft front bearing boss in the final PTO drive box (p/n 1K-1570) is broken and unusable. The local boneyard has a junk 77 with the PTO intact. Will the PTO assembly, including final drive box, final PTO drive gears and PTO clutch assembly from a 77 fit a 66?
J Schwiebert
11-02-2006 13:07:28
 Re: Oliver 66 PTO in reply to Ohiohills, 11-02-2006 04:51:21
Yes it will. Number one cause of that bearing failing is the shaft you attached to it does not either telescope enough or does not telescope freely. Questions? J.
