throttle lever friction discs
Skywalker3
11-01-2006 18:33:47
Can some one tell me the order of the friction discs and plates under the battery tray? I have two friction discs. I also have two metal plates: one for the linkage and one with a tab and hole in it to prevent it from turning. Then the spring and washer to hold it all together. Also is there supposed to be any lubrication on the discs or just dry? Thanks
oliver fan
11-03-2006 06:48:00
 Re: throttle lever friction discs in reply to Skywalker3, 11-01-2006 18:33:47
Your parts book will show the order that they go. First put the bolt down through the battery tray. Next put one friction disk up to the bottom of the tray. Next the steel disk with the tab, next the other friction disk, and the last piece is the steel disk that has the leaver attached. with all these parts pancaked together put the spring over the bolt and the nut, then tighten until you get the right tension with the hand leaver. Don't forget the double nut as that will keep everything from come loose when you use it.
chris Van der Vyver
11-04-2006 04:25:24
 Re: throttle lever friction discs in reply to oliver fan, 11-03-2006 06:48:00
What was the answer to the lubrication question? I am just fitting these friction discs to my 550. The whole throttle lever down to friction discs were missing.
oliver fan
11-04-2006 06:12:55
 Re: throttle lever friction discs in reply to chris Van der Vyver, 11-04-2006 04:25:24
chris,
As jim stated, NO to the oil or grease on the friction disks. To adjust the friction (to hold the hand leaver in place) you tighten the spring if the leaver does't stay in place. Loosen if you can't move the leaver fairly easy. Really quite simple.
Jim@concordfarms.
11-04-2006 04:53:51
I don't know what model of tractor the original poster was referring to, but on my 1650 the spring keeps pressure on the friction discs, which holds the throttle in position. The name of the game here is friction, not lubrication. Jim.
