Cockshutt 30 oil pump
Carl Tesch
11-01-2006 16:36:08
I have several Cockshutt 30 gasoline tractors in various stages of restoration. I need a new or good used oil pump for the 4B153 engine. Most Cockshutt 30 tractors I see at shows have the oil pressure regulating screw turned in all the way--so I'm betting that weak oil pumps are common on these engines. Where can I get a pump or one close the same dimensions that I can rework.
J Schwiebert
11-01-2006 18:27:32
 Re: Cockshutt 30 oil pump in reply to Carl Tesch, 11-01-2006 16:36:08
I sent you an e-mail. Before you blame the oil pump have you made some checks for internal oil leaks or measured your oil pump clearances? J.
Carl Tesch
11-02-2006 15:21:49
 Re: Cockshutt 30 oil pump in reply to J Schwiebert, 11-01-2006 18:27:32
I have had the engine completely dissassembled--all new crank and cam bearings.
I could have the gears and oil pump base plate resurfaced but the problem is that the oil is pumped up along the drive shaft thru the oil pump body. Pressurized oil then enters the main oil rifle of the block via an internal intersection. The shaft and body are worn and I am sure this is the main internal leak.
Thanks for the reply. Any ideas for finding a new or rebuilt pump or one similar that could be adapted for this use?
J Schwiebert
11-02-2006 18:29:30
 Re: Cockshutt 30 oil pump in reply to Carl Tesch, 11-02-2006 15:21:49
I sent you an e-mail. I would make up a leak detector and see where you are at. How is the t fitting that screws in the head. Remember it should restrict oil flow.
