Hooking up Generator.
Ryan Amstutz
10-31-2006 17:33:14
Hi,
I have a Oliver 60 tractor, and I was wondering if you could tell me how to hook up the Generator on this tractor. The generator was just rebuilt. It was not hooked up before, and I don't want to ruin it by hooking it up wrong. Thanks Ryan
B A Star
10-31-2006 22:50:00
 Re: Hooking up Generator. in reply to Ryan Amstutz, 10-31-2006 17:33:14
Originally the model 60 had a third brush generator.   If Original, it will have a cutout relay mounted on it.   You should have one wire from the "A" terminal on the generator to the relay.   With the relay mounted on the generator with the teminals away from the engine, the wire from the "A" terminal should go to the rear terminal on the relay.   Front terminal wire (battery) on the relay should go to the ammeter.   Second wire goes from the "F" termianl on the generator to the resistor mounted on the top of the light switch.
