Distributor Lubriction question
Skywalker3
10-31-2006 09:59:22
Hello, I am doing routine service on the my 1973 550 today. In my manual it says; "remove the pipe plug at the base of the distributor housing and fill reservoir..... ." It also shows pictures. My distributor does not have a pipe plug at the base. It does not appear to be missing, there is just no place for one. Is it a newer model?? Do I still need to fill the distributor with oil under the weight assembly? It appears to be dry under the weight assembly now. Also, I went to lube my generator cup with 3-4 drops of oil as the manual recommends. However, this too appears to be sealed with no place to add oil. As always, thanks for any information.
J Schwiebert
10-31-2006 14:11:56
 Re: Distributor Lubriction question in reply to Skywalker3, 10-31-2006 09:59:22
Is your distribuor cap held on with two clips or 2 screws?
Skywalker3
10-31-2006 17:14:23
 Re: Distributor Lubriction question in reply to J Schwiebert, 10-31-2006 14:11:56
The distributor cap is held on with two screws.
J Schwiebert
11-01-2006 18:25:46
 Re: Distributor Lubriction question in reply to Skywalker3, 10-31-2006 17:14:23
Your instructions are for the distributors that have the clips. Your manual was printed before that distributor became standard equipment. J.
Skywalker3
11-01-2006 18:35:03
 Re: Distributor Lubriction question in reply to J Schwiebert, 11-01-2006 18:25:46
Thank you J.
