Cockshutt 30 rear wheels
Wayne Kachmar
10-28-2006 19:50:44
Does anyone have information on the rear wheels of the Cockshutt 30. My rim today rusted thru and appears to be folding over on itself. Is the outer rim able to be seperated from the inner plate that bolts on to the hub? Are the rims a universal item that is customized to an individual brand of tractor or do I need to start the search for 38 inch cockshutt wheels? Any information and help is appreciated. Thanks.
candy
02-01-2007 11:37:28
 Re: Cockshutt 30 rear wheels in reply to Wayne Kachmar, 10-28-2006 19:50:44
we are looking for rims for a cockshutt 30 rear wheels. have 8 bolt 12/4/38
big jt
10-29-2006 06:43:36
You should be able to use a flat base rim to replace yours. Only thing you will need to do is put your lugs on the new rim. I have done this by welding the rivets to the lug and drilling a couple of holes in the rim to blind weld the lugs on. Once paint is applied and a tire put on you couldn't tell it was a replacement.
Don't know what width you need but M.E. Miller would be the first place I check.
jt
