Shifting a 55/550
Danny Yerks
11-30-1999 05:36:42
What's the trick to shifting between low and high range on a Super 55 and 550? I've been test driving a few and never know what gear I'm in!
Do you push down on the lever or pull up on it or what? Thanks.
jeff rzepka
11-30-1999 09:07:15
 Re: shifting a 55/550 in reply to Danny Yerks, 11-30-1999 05:36:42
no trick danny
just let go in neutral and let the handle
center itself then push forward or pull back depending which way you want to go.
if it's not going that easy maybe the centering spring is broken or the detents in the shifting shafts are sticking
mine shifts smooth as can be
good luck jeff
if spring is broken up top its a simple fix
Danny Yerks
12-01-1999 10:27:15
 Re: Re: shifting a 55/550 in reply to jeff rzepka, 11-30-1999 09:07:15
Thanks. As usual for me I was making it harder than it needs to be!
