Power steering pump replacement on 550
Farmritch
10-28-2006 07:19:00
I have heard the Cessna pumps are not available (never liked thier airplanes either) anymore What pump can or will replace the old orig pump??
P/N 155899-AS
Thanks Farmritch
luapp
10-29-2006 11:13:26
 Re: Power steering pump replacement on 550 in reply to Farmritch, 10-28-2006 07:19:00
i replaced one with one from northern hydrolics. i dont have the book here bbut it the little gear pumps they sell for 90 dollars for the biggest one of that group. only differenc is the fitting come out the side instead the back. works really well though.
J.Schwiebert
10-29-2006 05:40:06
Are you real sure on the Cessna hydraulic and airplane part. I taught a Gresen class for a vendor one time. They used Cessna/Eaton Piston pumps in conjunction with Gresen valves. That gentleman who was an Eaton employee said Cessna hydraulics originally came about because of the hydraulics needed on the airplane. J.
oliver fan
10-28-2006 07:34:02
First, the Cessna hydraulic co. is now part of Eaton Corp., and were never connected with the airplane company.
Second, The parts can still be found to rebuild your power steering pump. I know because I had mine done less than two months ago. Any hydraulic repair shop should be able to get the parts need.
As to getting another pump, I'm sure you can come up with something, but it will most likely not fit where the old one was.
