1800 1950 Fwa.
Terry
11-29-1999 18:01:03
I was wondering which would be more rare.An 1800 gas with Front Wheel Assist or an 1950 with front wheel assist an a Detroit.I alway's thought M.M. made alot of early FWA. tractors. I have run into a few Olivers as of late.Any guesses on how many built of each of these models of Olivers.Thanks
Tractor Guru
12-04-1999 18:16:17
 Re: 1800 1950 Fwa. in reply to Terry, 11-29-1999 18:01:03
I would think the 1800 gas with a front-wheel assist would be rarer, cause I've never seen one and I'm the Tractor Guru.
B A Starr
12-28-1999 00:18:46
 Re: Re: 1800 1950 Fwa. in reply to Tractor Guru, 12-04-1999 18:16:17
The early MM tractors that had the MFWD axles were dealer installed. Oliver tractors used the Clark Mfg. axle. I believe the MFWD tractors were introduced with the 1963 model year as a factory build. There was not a seperate serial number for the MFWD tractors. Oliver started the year with the next serial after the last S/N used the previous year and all tractors built had serial numbers in secquence regardless of model built. That pratice started in the 1950's.
tractorboy55
09-06-2000 22:12:20
 Re: Re: Re: 1800 1950 Fwa. in reply to B A Starr, 12-28-1999 00:18:46
On the comment about which tractor is more rare, Iwould have to say that the 1800 FWA is alittle bit more rare. I do know of one 1800 FWA gas along with a few 1950's. the 1950 could either come with the detroit 3 cylinder or the oliver 310 with a turbo. Ihad a 1950 T that I sold to my father and we still use this tractor on the farm. I hope this has helped you and that you enjoy Oliver tractors as much as I do.
JOHN GIBBS
09-22-2000 08:44:11
 Re: Re: Re: Re: 1800 1950 Fwa. in reply to tractorboy55, 09-06-2000 22:12:20
I DO NOT KNOW WHICH IS THE RAREST BUT IF ANYONE MAY KNOW WHERE A 1800 OR ANY FWA OLIVER IS WOULD HELP ME GREATLY. I HAVE 1955FWA AND USE IT ALL THE TIME. WOULD LIKE TO FIND ONE IN NEED OF SOME REPAIR.IF TRACTORBOY55 KNOWS WHERE ONE IS PLEASE E-MAIL ME AT [email protected] THANK YOU ALL FOR YOUR HELP!!
